Input switch between DP and HDMI to 1 monitor
mercurialzu
I have 1 monitor, and i'd like to easily switch between my PC (DP Output) and PS4 (HDMI Output) using a switch of some sort. Rather than use the monitor's in built source switching option, which is rather hard to get to.
I used to use a HDMI switch when I had both HDMI outputs, but now I have 1 DP and 1 HDMI. Any ideas? I can't seem to find a similar switch for DP
Using the monitors built in option is the best but you can get dp to hdmi cables and use that with your current switch.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
