Motherboard says low power promontory
Today i looked in hwinfo underneath the chipset for my motherboard and it says low power promontory is this normal
i have a msi gaming x470 max
Promontory is the chipset architecture. Low-power is an indication that it's energy optimized. Doesn't mean anything really. It's the same for virtually any Zen 2 capable board.
CPU: AMD Ryzen 9 5900X · Cooler: Artic Liquid Freezer II 280 · Motherboard: MSI MEG X570 Unify · RAM: G.skill Ripjaws V 2x16GB 3600MHz CL16 (2Rx8) · Graphics Card: ASUS GeForce RTX 3060 Ti TUF Gaming · Boot Drive: 500GB WD Black SN750 M.2 NVMe SSD · Game Drive: 2TB Crucial MX500 SATA SSD · PSU: Corsair White RM850x 850W 80+ Gold · Case: Corsair 4000D Airflow · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: Corsair K100 RGB Optical-Mechanical Gaming Keyboard (OPX Switch) · Mouse: Corsair Ironclaw RGB Wireless Gaming Mouse
Ok thanks and another question i have is that is turning game boost on in bios worth it or will it shorten my cpus life
That's mostly marketing nonsense. All it's going to do is adjust the power limits and voltages a little, such that your CPU *might* boost a little higher/longer. However, there's so many variables here, that there's no guarantee it's going to have any effect at all.
Technically, any change to power delivery can hurt components, but for something like this that you just flip a switch on, everything is going to be well within acceptable ranges, so lifespan should not be impacted.
  • 1 year later...
I know this is old post but I have been running the same board and an r5 3600 overclocked to 4.6ghz all core and it's been running that 24/7 since roughly the time you posted this and still passes cinibench no problem every time.
