Search In
  • More options...
Find results that contain...
Find results in...
Poor man’s rig have 200 more to invest in it.
My system has a gtx 950, e3-1220 v3, Patriot Viper 3 Series, Black Mamba, DDR3 8GB (2 x 4GB) 1600MHz Dual Channel, GA-B85M-D3V motherboard,  1tb Ssd from Samsung and a 2tb Sata drive. I am able to toss about $200 at it but nothing more as this is my twitch machine any suggestions?
Not really. Any sustantive upgrade would require more than $200. You might be able to get more capacity/higher clocked RAM, but there's only so high you can go with DDR3. I suppose you could throw in an RX 580 for ~$200, but not sure if you can fully utilize even that with the other components. Just keep saving your money. You can do much more damage with even $500 that would really make a big difference.
i think you should save up more for a new platform upgrade, not worth spending anything on this one as quadcores are getting obsolete, that gpu is not good enough for newer games and 8gb also isn't cutting anymore these days. I wonder how you were able to afford that 1tb ssd considering your modest specs.
The most underrated user and unsung hero of LTT Forum.
Casual Gamer and part time Youtuber.
Day Dreamer but lazy and lethargic when it comes to goals.
Always procrastinating. Avoiding challenges and getting out of comfort zone.
You'd probably be able to get a GTX 1070 for about $150. That'd make a nice improvement.
Build Logs isn't for questions. It's for people showing off their build.
Current PC:
OG Gaming Rig - Gone
get an rx 570 would blow that 950 out of the water
i7-8700k @ 4.8Ghz | EVGA CLC 280mm | Aorus Z370 Gaming 5 | 16GB G-Skill DDR4-3000 C15 | EVGA RTX 2080 | Corsair RM650x | NZXT S340 Elite | Zowie XL2730
Would a ryzen 5 3600 be any better? We been debating keeping the machine and using it till it’s completely useless then upgrading or upgrading now. This has been an extreme budget build for me. I built it in early 2019 for about 280 bucks. Most of that was the case. I think i might follow antitrust’s suggestion and upgrade the gpu to a rx570. That might carry me to early 2022
  • 2 weeks later...
Just ordered a ryzen 5 3600 hp omen machine with a gtx 1660 super. Hopefully it’s a better machine
