Is this B550 motherboard wireless better than
Solved by Haro,
5 minutes ago, Yashiees said:Should I choose the asus one that comes with the wifi
Well no not really it's not Worth it. The a pro is great and you can always go wired. If you can't you can just add a wifi card.
Patrick12 ·
Posted in Build Logs1 -
2
HALLOFFAMEGALAXFAN900 ·
Posted in Graphics Cards0 -
Tom80765412 ·
Posted in Audio0 -
txmatt1214 ·
Posted in New Builds and Planning3 -
7
3
Nevan Nedall ·
3
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
