Ryzen 5 3500U stuck at 400 mhz.
Solved by -rascal-,
1 minute ago, rx590overclocker said:Ok I just checked. In order from the first one to the third:
HTC
PROCHOT CPU
PROCHOT EXT
HTC and PROCHOT EXT throttling while CPU temperature is fine, can point do a bug, and updating the BIOS may resolve the issue.
As noted on the HWInfo forums.
https://www.hwinfo.com/forum/threads/what-does-the-htc-in-thermal-throttling-htc-mean.6073/
That or something else on the motherboard / system is overheating (e.g. chipset, VRM, etc).
https://www.hwinfo.com/forum/threads/r5-3600-regarding-prochot-cpu-ext.6151/
Also, if you can, check with Ryzen Master, and see what it says...
