Black screen gpu and fans and cpu works
Unabless
I installed new ram and I flashed bios and pc worked normally then I shutted it down cause it had 3gb useable of 12gb ram and I switched 8gb and 4gb and now pc works but no display and mouse and keyboard doesn't work I tried putting old one it doesn't work help me
Fans are spinning gpu is working cpu fan is spinning just no display
Are you using one stick, 4GB & one stick 8GB...?
I frequently edit any posts you may quote; please check for anything I 'may' have added.
Did you test boot it, before you built in into the case?
WHY NOT...?!
You use Windows 32bit version?
WHY NOT...?!
Yea
64 bit
Just now, BlueScope819 said:
Clear CMOS
How
Yea
Take 4GB out... see if work then.
WHY NOT...?!
64 bit
How
RAM should be two sticks... two 4GB for 8GB, not single.
WHY NOT...?!
Nope I'm gonna clear CMOS I think
I installed new ram and my pc was just black I putted old ram still black I cleared CMOS putted old ram it's still black everything works I just don't have display how to fix
Would be nice to know the specs.
Reseat everything. Try with one stick at a time.
Phone: Pixel 3a (Purple-ish).
Build Log:
I tried 1 stick nope also rtx 2060 6gb ryzen 7 2700x a 320m hdv r4.0
Other specs ?
Also this board will now power a 12nm 8 core. Let alone a 4 core.
Clear the cmos. Reseat everything. Try the cpu in a different system (like a friend's system).
Build Log:
Just now, TofuHaroto said:
Other specs ?
I cleared CMOS still not working
Build Log:
You need to get a better motherboard asap. The VRMs on that A320 aren't made for an 8 Core CPU.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z690 Aorus Elite AX DDR4 | GPU - ASUS TUF Gaming OC RTX 4090 RAM - Corsair Vengeance Pro RGB 64GB 3600mhz | AIO - H150i Pro XT | PSU - Corsair RM1000X | Case - Phanteks P500A Digital - White | Storage - Samsung 970 Pro M.2 NVME SSD 512GB / Sabrent Rocket 1TB Nvme / Samsung 860 Evo Pro 500GB / Samsung 970 EVO Plus 2tb Nvme / Samsung 870 QVO 4TB  |
TV Streaming PC: Intel Nuc CPU - i7 8th Gen | RAM - 16GB DDR4 2666mhz | Storage - 256GB WD Black M.2 NVME SSD |
Phone: Samsung Galaxy Z Fold 4 - Phantom Black 512GB |
Okay so can someone help me I installed new ram it didn't recognize it first so I flashed bios installed ram again and boom I had 16gb ram but 4gb ram usable so I shutted down pc swap slots and my pc is turning on but no display and keyboard and mouse is not working
Just now, NZgamer said:
What slots are the ram in? Can you try reseating the CPU?
Cpu is working fine everything worked fine until I swapped the slots
I have 2 slots only so both slots
is this a prebuild and if so how old
some computers such as inspirons or optiplexes have boards with ram limits less than others at the time
Try only one RAM stick at a time. But based on your description it almost sounds like your RAM is broken.
Brand new custom builded 3 months ago
Yea but I tried 2x4 and it's same
5 minutes ago, NZgamer said:
Can you try resetting the CMOS?
I did it its same
