Most silent fan to sleep with?
MS-DOS
I have this one:
https://askgeorge.com/en/office/free-standing-fans/rowenta-turbo-silence-extreme-ventilator/
But even on silent mode it's not quiet enough. It also has a led that goes on during silent mode which you can't turn off which isn't deal to sleep with but whatever, I can at least get rid of it putting a cardboard on top of it but the noise is a problem.
Is there a even more quieter fan that still retains decent cooling qualities?
3 minutes ago, MS-DOS said:
I have this one:
Ohhh... people fans, not ones that go in PC's.
I frequently edit any posts you may quote; please check for anything I 'may' have added.
Did you test boot it, before you built in into the case?
WHY NOT...?!
If only Noctua made these...
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
NF-A12x25
crap, thoughht you were talking about computer fans :)
If you're sleeping, the pc might be better asleep too.
Talking about human fans
haha, next thing you know people asking for what car to buy, in this forum.
Use silent PC fans.
Like Silent wings or shadow wings from bequiet.
I use a Dyson AM07 in my bedroom.
I have no use for Noctua fans, they are a joke 👌🏻
AMD R7 5800X3D | Thermalright Phantom Spirit 120 EVO, 1x T30
Asus Crosshair VIII Dark Hero | 32GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3060/1495 | WD SN850, SN850X, SN770
Seasonic Vertex GX-1000 | Fractal Torrent Compact RGB, Many CFM's
Panasonic fans, they are quiet but expensive.
I own a  TELEFUNKEN TF-16dc. It is quieter than my other AC fans, but it produces horrible bearing grinding noise.
Intel I7-10700KF stock - Noctua NH-D15 - A15+A12x25
Micron Ballistix Sport LT 4133MHz CL17-21-21-40 @1.45v
GIGABYTE AORUS 3090 Xtreme 1905MHz@0.919v/2010MHz@1.063v +900/750 memory clock
Seasonic PX-1000
Lian-Li Lancool II Mesh
  • 2 weeks later...
i think you would be better off with some earplugs.
My R2700XT build:  r7 2700 @4.1 Ghz max 65C - Sapphire Pulse rx 5700xt @1625Mhz 955mV 1300rpm fans, max 82C - Asrock B450 gaming k4 - Gskill Ripjaws 2x8GB @3200mhz CL16 - Be Quiet Straight Power E11 650w - Fractal Meshify C - EK-Kit S240 - NB eLoop 120mm PWM - Be Quiet Shadow Wings 140mm 1000rpm - Bitfenix Spectre LED PWM 120mm - Samsung 250GB 860 Evo - Seagate Barracuda 2TB
Peripherals:  Acer XF270HBbmiiprzx 144hz 1080p TN - CM Storm Quickfire TK - Coolermaster MK750 - CM Storm Reaper - Logitech G303 - Logitech G502 - Logitech G603
Audio:  Hyperx Cloud Stinger - Samson SR850 - Trust Screamer - Creative Gigaworks T20 II
