Laptop with Best battery life $1500 budget.
Solved by DailyProcrastinator,
3 minutes ago, IrishLuck said:I keep seeing conflicting reports and I really am just trying to find a solid laptop with the best battery life available. Any recommendations would be awesome.
My Dell XPS13 has been phenomenal and I've had it since new in 2017, newest gen is even better. Not having discrete graphics helps a lot especially if you do not need it.
What do you need the laptop for?
