How can i fit 3 fan in a single 4pin fan header?
Solved by PatrikYT_98,
you will need a fan splitter something like this https://www.ekwb.com/shop/ek-cable-y-splitter-3-fan-pwm-10cm
GOATWD ·
Posted in Peripherals0 -
1
AdamWarlock ·
Posted in Laptops and Pre-Built Systems5 -
Eamonc26 ·
Posted in New Builds and Planning3 -
1
WaitforAmpere? ·
Posted in Audio2 -
Benb112 ·
Posted in Troubleshooting6 -
LukeCorbishley ·
Posted in CPUs, Motherboards, and Memory41 -
pandaarts ·
Posted in Console Gaming7
play_circle_filled
Latest From ShortCircuit:
If you can only get one computer, get this one. - ASUS ROG G14 (2024)
