Molex, 3 pin, or 4 pin?
By
FishNuggets01
in Cooling
in Cooling
Solved by The_russian,
It depends on the fan and the build, most fans are quiet enough to just leave them on full so a molex fan works fine, but for builds that were focused on being quiet, I used 4 pin fans.
Fat Cat11997 ·
2
Anonymous Reviews ·
Posted in Member Reviews1 -
SOROBIN ·
Posted in Graphics Cards7
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
