Need help choosing components for my new pc
1 hour ago, Lord Szechenyi said:Budget (including currency): (not including motherboard and cpu) About 90000HUF
Country: Hungary
Games, programs or workloads that it will be used for: Star Citizen, Hitman 3 and anything else in the future
I already have a 1070 in my current computer, and although i do want to get a better one, it's not my number 1 priority and i'll be getting one of the 3000 series.
other than that, i have nothing, and i've never built a pc in my life
i am (very likely) going to buy this Motherboard (LGA 1200)
so other than cpu motherboard and GPU, can i get Case+Minimum 16gb RAM+Fans+Cpu Cooler+PSU for less than 90000 Forint?
Your budget is very constraint and building a decent PC is very hard. I have tried my level best and assembled few components as per your budget.
Hope this helps. You can upgrade as per your requirement.
RAM: Corsair Vengeance LPX 16 GB (1 x 16 GB) DDR4-3000 CL16 Memory
CPU Cooler: Cooler Master Hyper TX3 Evo 43.1 CFM CPU Cooler
Case : Thermaltake Versa H18 MicroATX Mini Tower Case
PSU : Cooler Master MWE Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply
Case Fan : Corsair CO-8950006 67.43 CFM 140 mm Fan
