Planning to buy a new motherboard but im kinda keen about the audio chipset. Will these audio chipsets make significant experience when playing games/watching movies> If so, out of the following which Motherboard has the best audio chipsets.
The headphones I currently use is Razer Naru ultimate.
Asus Tuf x570 wifi
Aorus Elite x570
Aorus ultra x570
https://linustechtips.com/topic/1219106-which-motherboard-has-best-audio-chipsets/
The X570 Ultra comes with the ALC1220 codec, which, at least on paper, is better than the ALC1200 found on the TUF X570-Plus and X570 Aorus Elite. That being said, the Ultra is quite a bad purchase in general and buying it just because of this reason is granted, quite stupid.
What's your budget for the motherboard?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
None of them, they all suck. I use internal soundcards on my Desktops, which are hooked up to stereo receivers, and a USB DAC for my headphones with my laptop. I would suggest doing the latter in your case, as it's typically cost effective and a substantial upgrade.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
Motherboard audio has come up a lot, the built in audio chips motherboards have these days are incredible. If OP is literally just playing games and watching movies, the motherboards audio will be fine. If this were an audio editing or audio consumption station where audio quality is of the upmost importance I'd say otherwise. While some DACs can be inexpensive it's still an extra cost over the motherboards built in audio.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - Sapphire AMD RX 7900XTX Nitro+ 24GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S24+ - Ceramic White 512GB |
MY CURRENT BUDGET FOR THE BOARD IS AROUND $250, HOPING TO PAIR IT WITH THE 3800X
The Strix B550-F and B550 Aorus Pro are around $180 and are very solid options. And both also feature the ALC1220 codec, relating to your original question. At around the same price as the X570 Ultra there's MSI's X570 Unify (which is a better board overall), but you probably don't need that high-end of a motherboard.
Also, I'd suggest getting the 3700X, unless the 3800X is within something like $10. The performance difference in real-world tasks is practically unnoticeable between them.
