Top Best Budget Gaming Wireless Mice?
Yonathan
Something Logitech, lower or around $100, something else than a G305 or other brands
Edited by Yonathan
depends, whats your budget?
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
2 hours ago, Yonathan said:
Something Logitech, something else than a G305 or other brands
g603. It has 0 latency, you can change the batteries so you don't have to trash it after a few years. It has bluetooth so you can use it with any laptop and some phones. 2 sidebuttons. Options: two AAs for reliability and battery life; one AA for gaming, lighter weight, better balance. A single 2000mAh AA lasts months, I hardly ever have to charge them. The scroll wheel is better than the g403's. It looks professional. It's not extremely expensive. Just don't lose the dongle.
I've had it since release (2017), I'm not going easy on it. I'm not trying to spare its wheel or buttons. I carry it with me in my backpack (in a separate pocket). The G on its back is faded, other than it's flawless
The software sometimes shits itself, but what software doesn't. (Not recognizing the first scroll step, messing with cursor speed, stuttering). I haven't noticed any issues recently though.
My R2700XT build:  r7 2700 @4.1 Ghz max 65C - Sapphire Pulse rx 5700xt @1625Mhz 955mV 1300rpm fans, max 82C - Asrock B450 gaming k4 - Gskill Ripjaws 2x8GB @3200mhz CL16 - Be Quiet Straight Power E11 650w - Fractal Meshify C - EK-Kit S240 - NB eLoop 120mm PWM - Be Quiet Shadow Wings 140mm 1000rpm - Bitfenix Spectre LED PWM 120mm - Samsung 250GB 860 Evo - Seagate Barracuda 2TB
Peripherals:  Acer XF270HBbmiiprzx 144hz 1080p TN - CM Storm Quickfire TK - Coolermaster MK750 - CM Storm Reaper - Logitech G303 - Logitech G502 - Logitech G603
Audio:  Hyperx Cloud Stinger - Samson SR850 - Trust Screamer - Creative Gigaworks T20 II
Like below a hundred bucks
you can go with the G603 that @00RaZoR11 recommended or with a G703 or razer basilisk x hyperspeed, the G604 may also be an option if you like larger mice.
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
