Need The Best Air Cooler For This CPU
Solved by ooqw,
4 minutes ago, GER_T4IGA said:Sidenote, what will be the purpose of your build? You are spending a lot on your CPU. If you are going for gaming you should try going 10600k+2080/S instead. Haven't done any math but for dollar/fps the 10900k is absolutely terrible. and if you don't care about money a 2080 Ti does do your framerate more good than a 10900k does. Just saying.
I have updated the list. I now have the NH- D15 and the meshify-C case with i7-10700k instead of the i9.
