Water cooling laptop
Solved by daveholland86,
22 minutes ago, Tamesh16 said:If you look in the forums people have done it, its not too hard, its just a bit difficult to make the machine usable afterwards, so it can take some custom parts to make that happen, but if you're just doing it for the sake of it with no intention of using the machine afterwards as a portable laptop, then you should be fine
Yeah, my first built will be a test to see if I can do it. Then if still interested I will refine it to being portable. My plan is keeping the air cooling system intact so the water loop supplements the air cooling but is not required.
