Lian Li PC-D600 will it fit a SSI EEB motherboard ?
Rick88
Hi !
I bought the motherboard  :
ASUS Z9PE-D8 WS Dual LGA 2011 Intel C602 SATA 6Gb/s USB 3.0 SSI EEB Intel Motherboard.
And the form factor is SSI EEB, is little bit confusing if that is a EATX size ?
Because i was thinking of buying the Lian Li PC-D600WB case.
http://www.lian-li.com/en/dt_portfolio/pc-d600/
I mailed Lian li . But no answer so far.
help me out please.
well e-atx and ssi eeb are physically the same size but the mounting holes are different so the lian li doesnt say it supports ssi eeb only the usual e-atx etc so im guessing u will have to make a few of your own mounting holes if u want to use this case but it will fit in the case just the holes might not all line up.
