minecraft bedrock not letting me join over LAN
3 minutes ago, Jezzdabezz said:
Make sure she has LAN play enabled
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
she does but it says there are one player available. but it does not show up!
Are both connected to the same network frequency it's a common mistake
Reminder⚠️
yes we are both connected to the same network and same frequency.
Idk is someone on a dns?
Reminder⚠️
what does that mean, i am not that good with my terminology.
if you want to know my router is a fritz box 3550 with cloud-flare dns.
Try disabling the cloud-flare dns
Reminder⚠️
i can't it is the default from my ISP.
Well then are both running the same version of minecraft?
Reminder⚠️
yes both on latest version.  1.16.1
i will restart and reinstall it, i think that might help?
Try
Reminder⚠️
11 hours ago, Kanna said:
Try
i fixed it, it was because we were both on the same Microsoft account on different computers.
 Yeah that explains why it didn't work
Reminder⚠️
On 7/1/2020 at 6:43 PM, BucketBoiAce said:
This is why Java edition, is better.
i have tryed it on java and it does the same thing, the reason i use bedrock is because we have old 10 year old laptops and they can't run java. because of the programming overhead.
