I have an Adata XPG SP8000 plugged into the third and last slot on my motherboard and this thing is running at like 10c-15c, which is not normal at all because when it was in my old PC, it ran around 40c's... Via CrystalDisk I used to get read and write speeds of around 3000+, now the speeds I'm getting are 550 and 460.
The only thing that looks different is the temperature, so I can't think of anything else it may be.
any help?  thanks
edit: my actual Windows drive is a Sabrent 500gb Gen 4 which is installed in the first slot and running normally, getting the advertised speeds and temps are 35c-40c...
You realize that 10-15c is way below your ambient temp, and you haven't told us that you're refrigerating the M.2.
Temps have to be very HIGH to have negative effects for all intents and purposes.
Besides, either the sensor is malfunctioning, the software is off, or you're just guessing as to the temp ;)
How are you measuring the M.2 temp?
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Sage Ryzen 7800X3D - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 CL6000CL32 32GB - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
OnePlus Ecosystem:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
The ambient temp of the room the PC is in actually is around 15c's... it's a storage room that's part of the garage, so they're both equally cold. I'm in the next room over I have a displayport cable routed through the wall to my monitor in my actual room.
The other thing is I don't think the sensor is off, (using Hwinfo)    and even if it was off, it still doesn't explain the really bad performance I'm getting.
edit: I'm gonna turn off my PC and take the heatsink off the drive see if that does anything, will report back
Which motherboard is it?
The third m.2 slot might be limited to SATA only, not NVME, and thus the drive might be running in some compatibility mode.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
OnePlus Ecosystem:
Other Tech:
It's
it's a Gigabyte X570 Aorus Master...   I think all 3 slots are Gen 4 capable
damn, removing the motherboard heatsink just made it run about 2 degrees hotter.....   so yea something weird is going on
8 hours ago, Juular said:
Check if that SSD uses PCI-e interface, not SATA. Smth like CrystalDiskInfo should report that.
yea it's normal operating as far as I see...   I left the PC on overnight and according to HWinfo something made it shoot up to 29c's Maximum during the night when the PC was completely idle, and right now it's sitting at 11c's...  this is one of the more head scratching things I've seen in regards to my own PC issues.
Ok I figured out what the issue was.....    the hotdamn Windows Power Plan.... I usually have it set to Power Saver since I'm a casual PC user, almost never play games nor do anything intensive.
Switched the power plan to Balanced and everything is working normal now.... whew, whatta dumb thing to go wrong, why would a powerplan kill my SSD anyway, makes no sense to me
