Troubleshooting 4 dimm run on 2400 or no post issue
Spec:
2700x
MSI X470 gaming pro carbon
4x 3200mhz Kingston predator rgb.
Situation:
Recently added two more sticks of ram into system. Previous two sticks was running with xmp profile 2 3200mhz.
But with 4 sticks, system won't post with any oc. Only manage run it default speed 2400mhz. (yet testing 2667mhz)
4 sticks is alot of pressure on the imc for zen +
A couple of things
Update the bios
Now set the soc to 1.1
Dram to 1.35 (1.4 if needed)
Set the frequency to 2933 with docp / xmp enabled
If it boots use memtest86 and OCCT to verify that it's stable
Anything over 2933 is technically an overclock to the imc for zen + so it's not guaranteed especially with 4 sticks
Good luck
Edited by TofuHaroto
Phone: Pixel 3a (Purple-ish).
Build Log:
A couple of things
Update the bios
Good luck
BIOS updated to second latest 2019 dec. as the latest  was beta.
I not the OC guy, just simply switch the xmp on....
DRAM 1.35 is talking 1.35v?
what is soc...
I have test the XMP1(2933)/XMP2(3200)both unable to POST.
maybe is was the cpu hard limit?
Yes
what is soc...
Soc ≈ memory controller
It means more things but that's part of it
Build Log:
what is soc...
override SoC voltage to 1.1v - 1.15v and DRAM 1.35v should be enough for 3200 MHz or lower
maybe tune down the sub-timing, your XMP profile could be too tight.. try 16-18-18-18-36 or higher
On 6/22/2020 at 7:08 PM, TofuHaroto said:
Yes
thank's for the help.
I think I manage to run the system with nb 1.1v, ram 1.35v.3200mhz on 18-20-20-36 or something similar timing.
Seen like the nb voltage was too low for 4 dimm. Only 0.7v as I seen that day.
Yet stress test on ram. Using few days no issue but will do it later while free.
