Netgear Power Supply Question
Solved by less_pointy,
I believe OP is specifically concerned with the input ratings.
Most important thing is that the output matches, which OP clearly understands. As for the input ratings: in theory this does not matter, if the output is correct, your device will work.
Differences in efficiency of the AD/DC adapter might make that brand A will consume more input power than a brand B (and this might translate to a different input amperage) - but both can have the same output specs.
