How to make music sound better.
CorruptedBloby
Hey, I was wondering if there was software or hardware that could enhance my music playback and make it sound amazing. I use an Arctis 7 if thats important.
PC Setup
GPU ZOTAC GAMING GeForce RTX 2080 Ti AMP
Case Master Case H500P Mesh
AIO Water Cooler Cooler Master ML360R
CPU Intel Core i9-9900K
Motherboard Gigabyte Z390 AORUS PRO WIFI
SSD Sabrent 1TB Rocket NVMe PCIe M.2 2280
Power Supply Corsair TX850M - 850 Watt - 80 Plus Gold Certified
RAM Corsair Vengeance RGB PRO 32GB 2666MHz
Replaced all fans with Thermaltake Riing Quads
Peripherals Name
Monitor 1 MSI MAG321CQR (2560x1440, 32 inch)
Monitor 2 HP OMEN 25 (1920x1080, 25 inch)
Keyboard Corsair K95 RGB PLATINUM XT - CHERRY MX Brown
Mouse Corsair SCIMITAR PRO RGB
Mousepad SteelSeries QcK Prism Cloth
Headphones SteelSeries Arctis 7 (RIP)
Speakers Logitech Z337 Speaker System
Tablet Huion H420
Um, erm, I mean, you can use software like Breakaway Audio Enhancer or Voicemeeter Banana to create a system-wide EQ if you're looking to shape your music, or you can invest in an external AMP/DAC combo from a company like Focusrite or Schitt Audio. I'll leave the specifics to someone more knowledgeable though, as I'm far from being on the up-and-up when it comes to higher quality audio gear.
Desktop: KiRaShi-Intel-2022 (i5-12600K, RTX2060) Mobile: OnePlus 5T | Koodo - 75GB Data + Data Rollover for $45/month
Laptop: Dell XPS 15 9560 (the real 15" MacBook Pro that Apple didn't make) Tablet: iPad Mini 5 | Lenovo IdeaPad Duet 10.1
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 | Panasonic TS20D Music: Spotify Premium (CIRCA '08)
To make music sound better here are your options from best value for money to worst.
1, remove 'enhancements'
2, use a lossless file
3, get better headphones
4, get an external audio solution
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
Would have thought 3 and 1 are the same thing and I'd put them above 2. I mean ALAC or FLAC do sound better but £20 headphones are £20 headphones.
Dirty Windows Peasants :P ?
But removing software enhancements is free and new headphones aren't, this isn't a list of what will make the biggest difference it's a list of what will cost the least.
@rice guru
Was value for money... But anyways getting everything to FLAC or ALAC can be expensive. and removing profiles won't magically transform a bad pair of headphones into a good one. If that improves the experience by 5% I wouldn't say it's better value than a set of headphones that cost say £100 that improves it by 70%
Thanks, i messed with some of my spotify settings and it actually made it sound better. I might look into an external audio solution, but will they work with the headphones i have? theyre bluetooth.
PC Setup
Peripherals Name
Tablet Huion H420
No, an external solution can not make bluetooth headphones better. There are decent cheap wired earbuds and headphones (KZ immediately comes to mind sub$10) but no, nothing can make your bluetooth headphones sound "better". They can make it sound different for sure but nothing can make it empirically better.
@rice guru
