Zen+ max soc safe voltage
Solved by Haro,
4 minutes ago, Islam Ghunym said:but first I want to know if max SOC safe voltage of Zen 14 nm and Zen+ 12nm should be the same or Zen+ should be lower. you know this is not core voltage. probably things different.
For the most part I like to keep it simple and keep it the same for all of them
Either way anything over 1.2 will be bad and unless your super overclocking or trying to get on a leaderboard or something 1.2 and Below (specifically 1.1 is the best voltage but you can stretch to 1.2) will be fine
4 minutes ago, Islam Ghunym said:actually would like to try and gain some experience. most of us does not even use 1,2V
Yea it's more of a higher voltage to get to 1.1 is Usually the sweet spot
