Search In
  • More options...
Find results that contain...
Find results in...
Fractal Design 804 Case Fans
Hi, I would like to buy a pair 140mm fans for the top of my Factual Design Node 804.   The top has a mesh filter so I'm sure if it would better to get an airflow or static fan?   Attached a picture of the top plate of the case and the mesh filter.   Thanks for any advice.
David
I'd recommend just getting two Corsair ML140's. I have them, and they're great, even at pushing air through a radiator
Either @piratemonkey or quote me when responding to me. I won't see otherwise
Put a reaction on my post if I helped
My privacy guide | Why my name is piratemonkey PSU Tier List Motherboard VRM Tier List
What I say is from experience and the internet, and may not be 100% correct
“Airflow or static” fan?  Do you mean a fan optimized for airflow vs static pressure?  That’s some pretty fine mesh and even high static pressure 140mm fans don’t have a lot of static pressure. Lacking specific experience with the case a high static pressure fan will be less likely to generate problems.  I don’t know if it’s specifically needed though.  A high static pressure fan will likely have less total airflow but it’s not zero.  I would consider the static pressure optimized fan he safer move, but I don’t know if it’s needed.  Are they the same price?
Aren't the ML fans a bit loud?  I know the 120mm versions are night/day compared to my Noctuas, even if you crank the RPM right down.
Router: i5-7200U appliance running pfSense WiFi: Honor Router 3 (~850Mbit peak throughput)
ISPs: Zen VDSL (62Mbit) + Plusnet VDSL (68Mbit) + Voxi LTE (~120Mbit) + Three 5G (~500Mbit)
I don't find them loud. They shouldn't because of their magnetic baring. When they're at or around 1500 rpm they're almost silent. My aio pump is louder than all 5 of them combined
Thanks for all the input.   It really helps a lot.   I think I'm going to test out the be quiet! Silent Wings 3 140mm fan.  Based off the Amazon reviews they have a good mix of air flow and static pressure.
David
David
Remember to quote people so they see your reply David.
I use a bunch of SW3 120mm's in my build. Very happy with them.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
I have similar question like you last time, my ML120 (non pro) were making a lot of noise when mounting on front panel mesh (fractal design mini c). So I changed to arctic p12s. The noise did reduced, however I can feel the airflow decreased. Still happy with the result tho because I can replace the exhaust fans came with the case with ML120s and the gpu idle dropped from 55 C to 49 C.
  • CPU
    Ryzen 7 3700x
  • Motherboard
    MSI B450M Mortar Max
  • RAM
    Klevv Bolt X 3600mhz CL18 overclocked to 3600mhz CL18 @ 1.35V. (latency 67 ns)
  • GPU
    Gigabyte Windforce GTX 1080
  • Case
    Fractal Design Define Mini C Windowed
  • Storage
    1TB HDD from Toshiba, 250 gb Samsung 850 evo, 2TB Western Digital SN750
  • PSU
    Superflower Eco Silver 600W
  • Display(s)
    Dell U2417H
  • Cooling
    Arctic freezer 34 esports duo, Arctic P12
What's considered quiet depends on who's listening. They're definitely too noisy at 1500rpm for people like me.
Some static pressure is definitely useful. SW3's are excellent and a fine choice.
They use magnetic bearings, so they're not super loud. Audible, but not a plane taking off. It's not louder than a corsair aio pump
My memory is that 120mm fans start making a good bit of noise after 800-1000 rpm.  The smaller the diameter the higher the rpm, the larger the diameter the lower the rpm.  That’s independent of the bearing or the particulars of the blade mostly. A heavily hooked blade can go a bit faster.
By magnetic you mean enlobal?  Maglev? I’m only familiar with very early versions of those.  They had to be very carefully balanced and only worked when set horizontally like sleeve fans.
Mine are 140mm. I think I screwed up and plugged them into a three pin fan header, so there's no PWM control. I also don't have a bachelor's degree in fan design, so I'm probably spitting garbage I heard from videos and Wikipedia
Mag lev I think. There's 3 at the front (vertical) and they spin great. There's also 2 at the top of my case.
Heh.  My bachelors is in fine art so likely even less applicable.  I’m mostly just repeating what I was told long ago.  The rpm thing had to do with the highest velocity reached by the fasts moving part of the fan which would be the pier tip of the blade.  Might be a super sonic thing I don’t know.
Top wouldn’t work with the old style.  The ones I’ve got wouldn’t work for shit that way.  Fan up they would be unlubricated sleeve bearings and fan down the fan assembly would just fall off.  I’m way out of date though.
Well, I'm glad I live in a time where maglev fans work properly at all orientations
Much of the noise is from the motor as opposed to the bearing.
ML fans needs 12v / pwm for the magnetic levitation to work properly. Without it, the fan won't last as long and may be noisier.
Huh, I learned 2 new things. They work properly (I think), so it might be an iCue problem, or because I plugged it into a mobo fan header instead of the lighting node thing. I don't know, I'll figure it out, thx
Your may anyway.  Mine don’t.  They’re quite old though.
12v / pwm is needed just for levitation and not for the fan to spin.
