psu fan spinning very fast and loud when running game
m0oble
anytime i run a game, gtav for example, my psu just starts blasting like 15 seconds after i open the game, can i make it quieter or is this normal. psu is thermaltake 500w smart btw
pc specs:
r5 3600
16gb ddr4 3200mhz
b450 tomahawk max
rx 6600xt
1tb ssd + 6tb hdd
meshify c
750w dragon or something psu idk
prolly get a new/Better PSU, its in the Tier D for the PSU list.
bro i bought this for a fucking optiplex you think i can just get a better psu all willy fucking nilly
pc specs:
r5 3600
16gb ddr4 3200mhz
b450 tomahawk max
rx 6600xt
1tb ssd + 6tb hdd
meshify c
Oh, I'm sorry, I forgot I can tell thru your oh so well documented post what kinda PC you're rocking but yeah I'm sure you can 2 second eBay search https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313.TR3.TRC1.A0.H0.Xoptiplex+PSU.TRS0&_nkw=optiplex+PSU&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=+optiplex
thats what i had im not hooking up an rx 570 to a 290w dell psu
pc specs:
r5 3600
16gb ddr4 3200mhz
b450 tomahawk max
rx 6600xt
1tb ssd + 6tb hdd
meshify c
Yo Sis, how about a little nicer language? You came here for help remember...
and you haven't giving specs of your system... just a "Wah PSU Fan too loud HLEP LOL!"
When the PSU Fan gets too noisy, it may be on the bring of a meltdown... so like Viridian said, a better more powerfull PSU is your go to.
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
i5 4590, 16gb ddr3 ram, xfx rx 570 8gb, and the psu. gpu and psu are brand new
pc specs:
r5 3600
16gb ddr4 3200mhz
b450 tomahawk max
rx 6600xt
1tb ssd + 6tb hdd
meshify c
without knowing what exact OptiPlex you're running I can only say look for small form factor PSU's like Silverstone's or Seasonic's other then that maybe your not getting the best air flow you can try modding your case I.E. drilling some holes and placing another fan
optiplex 9020 mt, i can add a pic if you need
pc specs:
r5 3600
16gb ddr4 3200mhz
b450 tomahawk max
rx 6600xt
1tb ssd + 6tb hdd
meshify c
so a quick googliedoo later and some late night math...
cpu and GFX Card together when hard pressed could go for 400 Watts use together... well being a 500 Watts PSU, adding Mainboard power use, and Ram as well as drives power use, and added peripherial, well 500 Watts is hard on the line and perhaps a little low.
Main System:
if by hard pressed you mean overclocked i havent changed anything about anything, everything is stock and i wasnt planning on messing with it
pc specs:
r5 3600
16gb ddr4 3200mhz
b450 tomahawk max
rx 6600xt
1tb ssd + 6tb hdd
meshify c
Looks like a usual ATX Psu in that case...
Main System:
no with hard pressed I mean worked full tilt like a demanding game.
I think overclocking an Optiplex, due to being a prebuild is out of the question 😃
Main System:
from what i can tell its a fat boy case and not the slim kind so that helps your options for either better air flow or a new PSU, IMHO id say better air flow and that could help.
so like i mightve just thought it was my psu fan being loud but it really might have been the cpu cooler, since gta was taking up like 50% of it and when i closed it along with the launcher it got quiet again
pc specs:
r5 3600
16gb ddr4 3200mhz
b450 tomahawk max
rx 6600xt
1tb ssd + 6tb hdd
meshify c
im not sure though
pc specs:
r5 3600
16gb ddr4 3200mhz
b450 tomahawk max
rx 6600xt
1tb ssd + 6tb hdd
meshify c
It's normal for your fans to spin faster (creating more noise) when the system is under load. This is often very noticeable for CPU and GPU fans.
This is also true of power supplies. The heavier the load, the more heat they're generating and the faster the fans will spin in order to try and keep it cool.
Take the side panel off the case and load up GTA or a benchmark and listen to what is making the noise. Once you determine for certain what is making the noise you can assess your options, such as setting a custom fan curve (for CPU/GPU) or perhaps buying a better cooler
so i pretty much dont need to worry
pc specs:
r5 3600
16gb ddr4 3200mhz
b450 tomahawk max
rx 6600xt
1tb ssd + 6tb hdd
meshify c
