Zephyrus g14, first laptop ssd replacement
Hi so I saw a video on how to upgrade the ssd and I'm not sure if I need to repurchase windows 10 or if there is a way to use the existing installation to install it on the new drive.
If the laptop came with the OS copy, then the key is embedded into the BIOS. Just install a fresh copy and it should auto activate.
 Share
