Hardline Tubing with Soft Tubing Fittings
Solved by HM-2,
2 hours ago, JESUS IS LORD said:moral of the story keep the insert in until you are 100 % sure the bend is right otherwise it will kink and look super jank-y
Moral of the story is buy the right equipment in the first place, and use it properly.
Buh ·
Bert the Derp ·
Posted in Displays0 -
HumdrumPenguin ·
3
AMKKAM ·
Posted in Troubleshooting3 -
5
4
play_circle_filled
Latest From ShortCircuit:
If you can only get one computer, get this one. - ASUS ROG G14 (2024)
