Laptop advertised as 2400mhz but shows 2133mhz
Solved by schwellmo92,
5 minutes ago, arb said:Didn't think of searching about the CPU's support. Then that answers it. ASUS should fix their specs.
Technically the RAM is 2400MHz RAM as you showed in the CPU-Z screenshot, it's just your exact specification has the lower end CPU which only supports 2133MHz RAM so the RAM is being ran slower for the CPU. If you had one of the higher end CPU's available in that laptop it would have ran the RAM at 2400MHz. I agree it is a little confusing and misleading but it would be more confusing to the general public for ASUS to try distinguish all the different combinations of specifications.
