CPU heatsink blemish - does it matter?
Go to solution Solved by Jurrunio,
Nah it wont, new paste will fill in all the gaps if there are any
I recently cracked out my 3 years old Wraith Spire that came with my 1600. I am planning to use it on a computer I'm about to build. I've never used it so it still had the pre-applied thermal compound on it, though the compound did turned yellow. I wiped it off with some ethanol, but found blemishes on the copper contact. The surface still feels very smooth. My first guess is that the thermal compound corroded the copper. Will this affect its cooling ability much?
Everyone on here be showing off their rigs, so here I go:
Main Desktop CPU: Ryzen 1600 @ 3.65 GHz Memory: 2x8GB @ 3200 MHz Graphics: NVIDIA ASUS 1070 MOBO: ASRock Fatal1ty AB350 Gaming-ITX/ac Storage: NVME M.2 Crucial P1 SSD; SATA Crucial MX500 SSD; Seagate BarraCuda HDD.
Acer Aspire 5755G CPU: Intel i5-2410M @ 2.30GHz Memory: 6GB DDR3-1066 SDRAM Graphics: NVIDIA GT 540M 2GB Storage750GB 2.5" 5400RPM HDD Display15.6" 1366x768
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
 Share
