Help Guys I kinda need to speculate a new build to replace my old core2 quad
Budget (including currency): below 10000 malaysian ringgit( 2500 usd) preferably lower than that
Country:  malaysia
Games, programs or workloads that it will be used for: Mostly triple a games and maybe some light photoshopping and adobe premiere
Other details :Oh exclude the cpu I can get a 10700k for a pretty good deal so
                         Peripherals are needed except for the mouse
                         upgrading from my core 2 quad and i5 7200u
                         going to buy in july?
                         resolution 1440p and wants to game on a ultrawide ips monitor
                         refresh rate anything above 100hz will do
Budget: Below Usd2500 for a pc,ultrawide 1440p monitor, peripherals,speakers
Thanks guys
Are you still going to have that 10700K deal in july?
Just get some 3200mhz CL16 RAM at least
most Z490 boards should be fine
going to want an RX 5700/XT or 2070 super for the better value higher end GPUs, the 5700 is ~10-15% behind but may be a lot cheaper.
Yep the deal is constantly on haha
true the 5700xt is like 400 ringgit cheaper than the 2070 super here
oh yeah do u have any good ultrawide ips monitors to recommend?
Most of them use the same panels, as long as it's 100hz you should be fine, have to check actual reviews otherwise.
I ask because there's always the R5 3600, which is half the price anywhere else
yea thats true but over here its always about 759 ringgit for the r5 3600 almost the same as the deal for the i7
 Share
