Throttlestop showing EDP current yellow under core and Ring
@vertexbrush - The PP0 Current Limit controls EDP OTHER throttling. The 4th Gen CPUs did not use IccMax which is why this option is grayed out.
Your current limit and power limits are both locked by the BIOS. There used to be a modified BIOS available for these laptops but there is not too much to gain by using it. Any increase in performance and you will be thermal throttling instead of power limit throttling.
The CPU core and cache offsets do not need to be set equally. If your 4700MQ runs stable with an undervolt of -107 mV, you are already doing quite well but you can try adjusting either of these further individually.
The default turbo ratios are 34, 33, 32, 32. To use any multipliers higher than this, you have to check the Overclock box or your request will be ignored. The max is 36, 35, 34, 34 when Overclock is checked since these CPUs support +2 bins of overclocking.
When using a Non Turbo Ratio of 1, there is no need to check the Set Multiplier option. Not checking this will free up a couple of CPU cycles.
If Power Limit throttling ever becomes an issue, I will teach you how to use the PowerCut feature. This tricks the CPU into reporting power consumption data way lower than actual power consumption so you can avoid power limit throttling all together.
