Cables of case fans
Solved by thestarsarehigh,
You can connect it only to the Molex. It will run at full power all the time.
The 4 pin is for both power and using the mobo or OS to control the fan.
Probably not a good idea to plug both in simultaneously.
12345678 ·
Rummers ·
Posted in New Builds and Planning3 -
a7med ·
Posted in CPUs, Motherboards, and Memory1 -
5
1
moondogkill ·
Posted in Cooling1 -
1
snaphappy7530 ·
Posted in Troubleshooting4 -
JanS0lo ·
Posted in Troubleshooting3 -
3
play_circle_filled
Latest From Linus Tech Tips:
Every Monitor Fails This Test… Except One - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
