Help me choose a monitor
Sirius_IV
 Share
Hi, my current monitor just died so I'm looking for a new monitor. I'm a casual gamer and a programmer. I also watch a lot of YouTube and movies. I have an AMD GPU so FreeSync is on my bucket list. My budget and choices are limited. Following monitors are available locally so help me choose from one of these please.
  1. https://www.asus.com/Monitors/VZ229HE/
  2. https://www.techlandbd.com/samsung-ls22r350-75hz-gaming-monitor
  3. https://support.hp.com/lt-en/document/c05873308
  4. https://www.lg.com/hk_en/monitor/lg-22MK600M
THANKS IN ADVANCED.
Actually i wouldnt recommend any of these. Whats your max budget? IMO even with productivity you'll love to have 120Hz or 144Hz. The AOC 24G2 would be awesome if you can afford it and it's in stock in your region.
About monitor marketing BS
CPU: AMD Ryzen 5 5600X - Motherboard: ASUS ROG Strix B550-E - GPU: PNY RTX 3080 XLR8 Epic-X - RAM: 4x8GB (32GB) G.Skill TridentZ RGB 3600MHz CL16 - PSU: Corsair RMx (2018) 850W - Storage: 500 GB Corsair MP600 (Boot) + 2 TB Sabrent Rocket Q (Storage) - Cooling: EK, HW Labs & Alphacool custom loop - Case: Lian-Li PC O11 Dynamic - Fans: 6x Noctua NF-A12x25 chromax - AMP/DAC: FiiO K5 Pro - OS: Windows 10 Pro - Monitor: LG C2 OLED 42" - Mouse: Logitech G Pro - Keyboard: Logitech G915 TKL - Headphones: Beyerdynamic Amiron Home - Microphone: Antlion ModMic
I just want a cheap one for now...will get a 32 inch 144hz later so don't wanna waste more than $150
There is a 75Hz variant of the AOC 24G2. I have this one myself (Because at the time i didnt know there is a 144Hz variant for 30 € more). Bought for 150 € in Germany and it's perfect for a secondary monitor.
Just checked AOC 24G2 is not available here right now. And things are a bit overpriced here in Bangladesh so that monitor you specified costs more than $200
Well in that case you can pretty much pick whatever one is the cheapest. At 75Hz IPS there is not much the manufacturer can do extremely wrong. If it will later on only serve as a secondary display it wont matter that much either. I'm sorry that i cant narrow it down much more...
Ah okay I see...
Well umm although this will just be a secondary monitor but I intend to keep it so I was just wondering if any of those are better for longevity...
17 minutes ago, Sirius_IV said:
Ah okay I see...
Sorry but what do you mean with "longevity"?
 Share
