How to fix this laptop's temps problem?
So my aunt who has 2 toddlers sent me her laptop to try and fix it as she claims her toddlers played around with the windows settings and ruined it and she's got no experience with PCs whatsoever+they made it fall 2 times but it still works and still functions, I installed windows 10 pro 64 bit on it but I noticed a problem
The laptop is Toshiba Satellite C660 with core i3 380m and 2 GBs of DDR3 800 MHz RAM and intel HD GPU, at first while installing windows it worked fine but after I started using it the laptop got really hot, like really really hot, the CPU hit 85 C then the laptop shut down due to overheat, I will pin a photo of where the heat exactly is, but why did the laptop get so hot in such a short time even though it was idle? And how can I fix that?
My guess is that from the drops, the cooling mechanism got messed up/destroyed if it overheats on idle. Did you physically open it up?
It needs a good teardown and cleaning. I have the very same model upgraded to a i7-640M. Also be sure the kids aren't using it on a blanket or anything.
Main: AMD Ryzen 9 3900X @ 4.2 GHz, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Fedora 36 x86_64
Secondary: AMG Ryzen 5 5600G, 16 GB 2667 MHz DDR4, Fedora 36 x86_64
Server: AMD Athlon 3000G, 16 GB 2400 MHz DDR4, TrueNAS Core
Home Laptop: Intel Core i5-L16G7, 8 GB 4267 MHz LPDDR4x, Windows 11 Home 21H2 x86_64
Work Laptop: Intel Core i7-10510U, NVIDIA Quadro P520, 8 GB 2667 MHz DDR4, Windows 10 Pro 21H2 x86_64
1.) I have similar laptops, 2gb of ram with an HDD and Windows 10 is...nauseating to say the least.
2.) Old laptop, dried up thermal paste - take it apart and repaste everything and clean out the intake/exhaust ports.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
I don't exactly have enough thermal paste to repaste everything inside it, probably only the CPU
One thing to note about Arrandale laptops: They will not accept 16 GB of RAM. 8 GB Is the very limit.
One of these days, I'll get a 4 DIMM Clarkfield laptop, where I'll expect the very same behaviour.
I just run Manjaro on them instead :)
It will be CPU and GPU just like on a regular PC if it has a dGPU.  If not enough thermal paste, tell her to order some and keep the balance as service for the work done for the family.
Actually I do that for her for free, I mean she's my aunt
Edit: but won't I have to repaste the VRMs and MOSFETs too?
The CPU is the only thing you'll need to repaste (These do not have dedicated graphics). Be careful, as it's a MCM with no heat spreader. Pic attached. Make sure to spread the paste thinly over the entire silicon area, and to not chip the silicon, it's quite fragile.
Then buy the TIM, you said you didn't have TIM so you want to fix laptop well...
I guess I could advise using Toothpaste but...I wont.
I do have TIM but it's not reliable enough, it's a chinese called "HY610"
Just now, InfinityVive said:
I do have TIM but it's not reliable enough, it's a chinese called "HY360"
Have you used it?  If its non conductive its better than nothing/toothpaste.
I also have chinesium tubes of paste that come with my aliexpress orders of heat sinks - and if Im being honest here - they remind me more of TG Kryo than any of the other name brand pastes I own.
If it works, it works no?  And the difference between no paste (or dried paste) and "okay" paste that still transfers heat will probably fix the laptop.
It does work, but it is not the best, here's a video that compares it with other pastes https://youtu.be/q1sj6dzu5BI
Cant watch on this network atm, so you have a choice, use it, have her buy some and keep the balance, or don't try to fix the thermals by replacing TIM.
To cut things short, here are the results
Aida64 stress test on i7 3520m in oC
Noctua NT-H1: 85
GD900: 86
HY810:86
Arctic MX4: 86
HY510: 89
Zalman ZM-STG2: 89
HY880: 91
HY710: 93
(HY610):93
Noctua NT-H1: 85
GD900: 86
HY810:86
Arctic MX4: 86
HY510: 89
Zalman ZM-STG2: 89
HY880: 91
HY710: 93
(HY610):93
Changes nothing - either use it, get more (her or you), or don't fix it lol.
 Share
