FPS drops after cleaning PC. Plz Help!
Hsuyaa
Go to solution Solved by Hsuyaa,
So i DDUd the drivers and also reseated everything. Sadly the lag still didnt get fixed. I realized it wasnt my gpu but my cpu that was the problem. it seemed that the cpu clock dropped from 4.4 ghz to merely 10 Mhz or something at times. I tested cpu stability using Intel Extreme Tuning Utility and found that memory test made the huge lags happen. Then i realized i had swapped the 2 ram sticks i have around in the ram slots. I use one of those sodimm to dimm converter to use a 8 gb laptop ram on my desktop. I swapped them back to how they originally were and the lag is gone! So i guess that was the cause. Thank you guys for ur input! :)
Thanks to everyone who help me. A few days back i decided to give my pc a clean up because i had not done it for a while. I reapplied thermal paste on cpu and on the gpu. I cleaned the fans n all. When i opened up the gpu i saw alot of the thermal paste was collected around the die and was in a hardened state. I decided to remove it with a soft plastic knife. I scraped with minimum force removing the hardened paste. Then cleaned the dye with a microfibre cloth,reapplied paste and that was it.
        To my dismay, once i fired up some games they had massive fps drops which wasnt the issue before cleaning. But this is the weird part. Whenever i alt tabbed out of the game or opened my task manager and back, the fps drop was gone and everything went back to normal. I thought this issue might go away but it has been a few days since its doing this. Thing that i have noticed in the task manager is the gpu usage randomly jumps to around 40-50% whenever the lag comes in. Its not just that the games lose fps but even normal tasks such as typing in ms word or watching a video.
        The issue is really annoying and i'm not sure what to do to fix it. Pls guys any input is valuable. Thanks :)
DDU drives and clean install them
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500 gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb Adata XPG 6000 lite, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
1 minute ago, Shimejii said:
Should say what game and such. Sounds like Windows is the issue not the GPU.
  I mostly play games like Doom/GTA 5/Minecraft . Some old MMOs. I use two screens,one for playing the game and other for surfing youtube. Before the cleaning everything worked fine. But not now.
Alright i'll try that. However it was working all fine before the clean. I had not updated the drivers or anything when the issue came up. I'll still give it a try. Hopefully its a driver issue
windows will auto mess with drivers
