3rd Monitor question
GeorgeKellow
 Share
Hi Guys
i currently have 2 LG 27UK600 4K monitors. I am looking to get a 3rd monitor
i was thinking of getting a 144hz 1440p monitor to put in the middle of the 4K monitors.
Will I experience anything weird with 2 monitors being 4K and one being 1440p?
i have a 1080ti and with the games I play I will be hitting 144fps
looking to buy a iiyama red eagle 27inch model
The only 'weird' thing is that Windows think your monitor's resolution also is its physical size.
That means your cursor can get 'stuck' at certain parts of your 4K monitors:
You can only 'pass' from one monitor to another in the blue areas. The red area is not used space, which means your cursor can get stuck on the green parts.
Not a big deal, but just something to mention I guess.
 Share
