Search In
  • More options...
Find results that contain...
Find results in...
EVGA 2070S model
zpmarcos
 Share
Hi,
Which one of these do you recommend:
  • EVGA GeForce RTX 2070 SUPER KO GAMING - 540€
  • EVGA GeForce RTX 2070 Super Black Gaming  - 555€
  • EVGA GeForce RTX 2070 Super XC Gaming - 580€
Already looked at Tier List and cant find xc gaming and Ko gaming...
Which should I buy?
Best Regards
KO has traditionally been the "anything that can get cheaper without breaking Nvidia specs are cheaped out" card, though I guess it's only the PCB components ths time as 3 cards seem to share the cooler.
As for the Black and XC, they are the same apart from the fan shroud. XC had transparent plastic, Black has opaque black plastic
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
do you have extra money to spend or are you on a budget?
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
I think because of my case, max size must be <270mm
Well the ko is the lowest in quality obviously
It probably just has a pcb or a chip that can't overclock as good and their coolers are cheaper
As for the black and XC they are basically the same interms of pcb but it's a different cooler
As @Jurrunio said
Phone: Pixel 3a (Purple-ish).
Build Log:
 Share
