Best Bank for Buck Upgrade from 1050ti?
Mark123!
Hello, I have a 1050ti that is about 4 years old now. I would like to know what is the best bang for buck gpu for smooth 1080p gaming. I am willing to spend around 300-400.CAD My gpu is paired with the i7-8700 and it is a dell prebuilt system hence the older gpu with new cpu. Any suggestions are helpful!
An RX580 would be like a GTX 1060/1070. That might be a good option and is cheap used. You could also get a RX5700xt or a 5600xt or a 2060 Super
Please tag me @Windows9 so I can see your reply
Personally, I just don't feel that a 1 tier upgrade a rx580 after 4 years is an upgrade that is really worth doing, I guess if the used price is good enough, then sure.
Those other recommendations seem pretty good in my book though.
12 minutes ago, Ohsnaps said:
Man options options options im assuming thats USD correct?
Sorry my bad its CAD
Alright I will look into that thanks!
Also look on Aliexpress for used GPUs
Save your wallet, save the environment
The 1660 super is an excellent choice if 1080p 60Hz is your target
https://ca.pcpartpicker.com/product/ByqBD3/evga-geforce-gtx-1660-super-6-gb-black-gaming-video-card-06g-p4-1061-kr
Even a little overkill to be honest. Gives you some room to reasonable upgrade to 144Hz down the line.
Primary PC:
Beat me to it dang it lol
Phone: Pixel 3a (Purple-ish).
Build Log:
Thanks for the suggestion
