Will my FX-8350 be a bottleneck?
waterjug
Currently I have an FX-8350 paired with a RX 460, and I'm thinking about upgrading the 460 to a 570 or 580, because I did the math and I would break even selling my current card. Worth the upgrade?
linus sex tips
It would be an upgrade but modern games will probably have some stutter.
ok, is there a site that can calculate bottlenecking
I have a fx 8150 at 5ghz and at 1080p the max you can go is the rx 580
1440p prob a gtx1070
thats it, the rest will bottleneck.
Just look for a ryzen 1400 or 1600 for cheap and a cheap b350 board
