Search In
  • More options...
Find results that contain...
Find results in...
120mm case and a 140mm fan PSU
Hello,
So i just looked into my case's specifications and it seems it supports 120mm psu fan not a 140mm psu fan.
Do i need to replace the case ????
Case is abkoncore h250x ( not a known company but a nice case )
Psu is corsair RM650x 2018
12 minutes ago, Atomicest said:
Hello,
the psu fan size normally doesn't make a differnce in cases tbh
I don't see anything about a 120mm fan when I looked it up
Your psu should fit in the case btw
Please quote or tag  @Ben17 if you want to see a reply.
If I don't reply it's probly because I am in a different time zone or haven't seen your message yet but I will reply when I see it ?
The PSU fan as nothing to do with case fan .
The case fans will push or pull air to the outside of the case. The PSU fan will pull or push air the power supply case itself.
There are 2 thing you should consider , in my opinion . PSU physical size, will it fit inside the case, and is it power full enough.
I just check the physical --
PSU -- 150 mm x 86 mm x 160 mm
Case -- will accept PSU 195 mm to 205 mm  ( Not the full description )
You should look yourself to confirm
