First build, but what comes AFTER?
I've seen some videos on assembly, but only a few touch on what comes after. Meaning, bios stuff. I've never had any experience doing anything like that before, and it quite frankly has me far more rattled than anything regarding putting parts together. Are the bios fine out of the box? Will they auto update, or is this a manual operation?
My build
      AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor
      MSI MEG X570 UNIFY ATX AM4 Motherboard
      G.Skill Trident Z Royal 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory
      Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive
      Asus GeForce RTX 2060 SUPER 8 GB DUAL EVO OC V2 Video Card
      Cooler Master HAF XB EVO ATX Desktop Case
      EVGA SuperNOVA GA 850 W 80+ Gold Certified Fully Modular ATX Power Supply
Also, I'm curious about case fans. My PC will be located in the basement (gotta keep up with stereotypes, ya know) where in the summer it averages about 20c. Would the stock case fans and gpu/cpu fans be enough? I won't be overclocking for a while.
I appreciate any and all feedback, thanks.
X570 is ready for the 3900X out of the box, no need to update to get it to work.  There will be BIOS update instructions for when you do want to update it tho.
20c ambient is cool for a PC, you're more than fine.
Honestly, you build a PC and then use it.  Now if you want to talk about your build at all, it seems a little unbalanced. But I don't know exactly what you're using it for.
TBD - AMD Ryzen 7 7700x - MSI 6900xt Gaming X Trio - Gigabyte B650 Aorus Pro AX - G. Skill Flare X5 DDR5-6000 32GB - Samsung 980 1TB x4 - Super Flower Leadex V Platinum Pro 850 - ON THE WAY: EK-AIO 360 Basic and ThermalTake Core P3.  Looking forward to building week of Dec 5th.
Emma : i9 9900K 5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200Mhz - 750 EVO 512GB + 2x 860 EVO 1TB (RAID 0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - AOC AGON 35" 3440x1440 100Hz - Mackie CR5BT - Corsair Virtuoso SE - Logitech G910, G502 - Cooler Master Universal Graphics Card Holder
Plex : Ryzen 5 1600 - Gigabyte B450M-DS3H - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - 840 EVO 256GB + Toshiba P300 3TB - TP-Link AC1900 PCIe Wifi - Cooler Master MasterWatt Lite 500 - Antec Nine Hundred - Samsung 27" + Dell 24"
Raven:  Intel i3 10100F - ASRock H410M-HDV - G. Skill Ripjaws V 16GB 2666Mhz - MSI 1050Ti 4GB - Inland 256GB SSD + Toshiba 2TB HDD - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Spectre 24"
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Lenovo 720S Touch 15.6" - i7 7700HQ, 16GB RAM, 512GB NVMe SSD, 1050Ti, 4K touchscreen
MSI GF62 - i7 7700HQ, 16GB 2400 MHz RAM, 256GB NVMe SSD + 1TB 7200rpm HDD, 1050Ti
The most important thing to change yourself will be ram speed. Enable XMP/DOCP (whichever your motherboard has) so that your ram is not stuck at 2133 or 2400 or whatever the stock speed is.
After that you can try changing ram speed and whatnot, but it's not important for the function of the PC.
Primary PC:
Linux Proliant ML150 G6:
Dual Xeon X5560 - 24GB ECC DDR3 - GTX 750 TI - old Seagate 1.5TB HDD - dark mode Ubuntu (and Win7, cuz why not)
Trash beauty:
Xeon X5550RX 570 4GB (defective) -Fattydove Racing 240GB - WD Blue 320GBHP Z400 - 6x2GB DDR3 1066 - EVGA 450W3
As far as BIOS goes. if it's not broken maybe its best not to fix it. If something goes wrong then the motherboard may be left unusable.
Get your Windows install medium if you use Windows and install that sucker, make sure you got all updates before you move on. Then go to your boards support page at the MSI site, grab your drivers and install them. They may have instructions so pay attention. Go to Nvidia and get your 2060S drivers and if you have anything else that need drivers and don't got it automatically then go get those.
Now is a good time to enable any XMP and from there you can go game or work or do what the computer is meant to do. :D
Just a gaming PC. Mainly Cyberpunk 2077.
Should be fine, got a whole lot of CPU there ;)
Other Tech:
 Share
