Mid-Range GPU for Adobe Premiere Pro
11 hours ago, Jamie_Milk said:Hey Bellabichon, im back again...
i was wondering what do you think of the MSI GeForce RTX 2060 Super ARMOR OC 8GB GDDR6 ?
i had a long talk with my editor and he said that he won't be doing any 3D animations or heavy 6k/ RAW or RED Files. Mostly just Lightroom, PS, Adobe PP editing 4K. You think this card should be sufficient?
That GPU should be sufficient for that workflow. The hardest-hitting task on your GPU will be 3D rendering, so if that's not in the picture, you can easily step down to the 2060 Super. The only noticeable difference will be your encoding times in Premiere Pro (GPU acceleration makes a big difference in video encoding), but if you can wait a few extra minutes when you're rendering video, I don't expect that you'll encounter issues.
