Low speed on card
TomasFer
 Share
Hey! Ive got a zotac 2070 super twin fan, the problem is I resetted my pc, before the reset I used msi afterburner to get the card from 1905 mhz to 2040 mhz (+130 on core clock) and from 7001 mhz to 8001mhz (+1000 memore clock) the thing is that after the reset I want on msi after burner, put the same values (+130 and +1000) but i get max 1910 mhz and 7001 mhz, also the values fluctuate a lot, like right now with no usage values are at 700 core and 800 memory, which wasnt the case before, the values were always on minimum 1700 mhz core and always 80001 mhz memory. Im sure there is a setting for it but I did it long time ago so i dont know how to do it again.
Thanks for anyone helping in advance! :)
please delet post, posting it againt with some pictures to explain
 Share
