Should I upgrade my ram? Help!
Solved by Fasauceome,
If your current ram doesn't overclock very well, you should definitely consider some faster ram. DDR4 3200 is not terribly expensive.
AdityaSaraf ·
Posted in Displays2 -
gooseta ·
Posted in Troubleshooting5 -
Dareios-Gintoki ·
Posted in Troubleshooting6 -
1
220VoltsallCore ·
Posted in Displays9 -
7
xo33 ·
4
Linkinworm ·
Mortal_2077 ·
Posted in Graphics Cards2
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
