Using 1070 for compute and igpu as output
PositiveRaisin2
 Share
When I try to plug my monitor into my mobo it complaints that there is a dedicated gpu in the system and to plug into that. This is a mobo from a prebulit.
What is the prebuilt specs ?
Does the GPU not display an image because of this prompt?
Phone: Pixel 3a (Purple-ish).
Build Log:
i bet its probably a "feature" of the firmware intended so that people don't get their new pc and use shitty integrated graphics for everything.
CPU: AMD 3600X
GPU: Nvidia 3070 (planned)
motherboard: MSI B500-A PRO
memory: G Skill Ripjaws V 2x8 GB 3600Mhz CL16
PSU: EVGA B3 650@
Case: NZXT H510
wireless network adapter: intel ax200
I'm pretty sure pre builts don't have proprietary firmware for their chipset they won't bother lmao
Build Log:
i cant boot when the message appears.
Can the PSU handle the discrete GPU
Like does it have a pcie connector?
Also what is the prebuilt
Edited by TofuHaroto
Build Log:
my specs are in my bio i think
Yea but what is the name of the OEM build lol
Build Log:
"prebuilts" as in "took standard components and assembled them" no, but the big OEMs like Dell, HP etc make their own motherboards and firmware.
See if you can find an option in the BIOS to keep the iGPU enabled when a discrete one is present, of there's none you're basically SOL.
F@H
Desktop: i7-5960X 4.4GHz, Noctua NH-D14, ASUS Rampage V, 32GB, RTX3080, 2TB SX8200Pro, 2x16TB Ironwolf RAID0, Corsair HX1200, Thermaltake Overseer RX1, Samsung 4K curved 49" TV, 23" secondary, Mountain Everest Max
GPD Win 2
My bad 😅 lol I always association that word with OEM builds just kind of muscle memory lmao
Build Log:
 Share
