Converter for GPU Fan cable to Motherboard fan header?
Solved by Edgar R. Zakarian,
8 minutes ago, Applefreak said:Just carefully remove the red and black wires and put them into a 3 pin fan connector. You can buy those or use one from an old fan. You could also just cut the wires and connect them to those of, again, a dead fans cable. PWM won't work because there is no signal cable, so voltage control only.
I think this is what I was looking for.
Any reason pwm/fan speed control wouldn't work with this? As I see it, 4 pins does include signal and PWM, instead of the GPU, I can control it though my mobo chassis fan header.
