Search In
  • More options...
Find results that contain...
Find results in...
ryzen 5 1600af max freqency is 3.35ghz while gaming
i have
ryzen 5 1600 af
2x8gb 3200mhz ram
a320 s2h gigabyte (with bios f41)
my cpu never goes past 3.4 even 3.35ghz while underload whether in cinebenchr20 or while gaming
it also has the same score as the non af model although i confirmed it's the af model in cpu z with the 12nm
i saw this review on hardware unboxed and i am confused it has core speed of 3.7ghz
https://imgur.com/a/pwPKcHn
Temp when gaming 68
benchmark 85
Weather in egypt is hot 44°
If this is following stock 1600 settings, that is normal.
Before you reply to my post, REFRESH. 99.99% chance I edited my post.
My System: i9-10900KF 5.1-5.3ghz @ 1.365v // Corsair iCUE H150i Elite Capellix // Gigabyte Z590 Aorus Elite AX // 32GB (4x8) Crucial Ballistix Elite DDR4 4000/CL18 // ASUS RTX 3080 TUF OC // Corsair 5000D Airflow // Corsair SP120 RGB Pro x7 // Seasonic Focus Plus Gold 850w //1TB ADATA XPG SX8200 Pro/1TB Samsung 860 EVO/2TB Seagate 7200RPM Hard Drive // Displays: LG Ultragear 32GP83B/Lenovo L24Q-30/Lenovo L24Q-30 // Glorious GMMK TKL // Corsair Harpoon Wireless // Corsair H70 Gaming Headset
Wife's System: i9-9900K Stock // Cryorig H7 Quad Lumi // Gigabyte Z390M Gaming // 32GB (4x8) Corsair Vengeance LED DDR4 3200 // ASUS KO RTX 3070 // Cooler Master Master Box NR400 ODD // Seasonic Focus Plus Gold 850w // 1TB ADATA XPG SX8200 Pro/1TB Samsung 860 EVO/4TB Western Digital HDD // Displays: LG Ultragear 27GL83A-B/AOC AGON AG241QX/ASUS VG248QE // Corsair K68 Mechanical Keyboard // Corsair Harpoon Wireless // LG BDRW // NexStar 5.25" USB 3 Enclosure
TV Gamer: i7-8700K 5.0ghz All-core delidded @1.375v // Deepcool Gamerstorm Assassin III // Gigabyte Aorus Z370 Gaming 5 // 32GB (4x8) Corsair Vengeance LPX DDR4 3200 // XFX 5700XT RAW II // Corsair 275R Airflow // Corsair 650M Vengeance 650w // Intel 660P 1TB NVME M.2 SSD/4TB Western Digital Blue // Display: 50" Westinghouse 1080p // Rii Wireless Mini Keyboard w/Touchpad/Xbox One Controllers
TV Gamer 2: Intel i3-10100 // ASRock H410M-HDV/M.2 // 16GB (2x8) DDR4 T-Force Vulcan 2666 // XFX RX 580 8GB XXX Edition // Rosewill FBM-X2 // Gigabyte P750GM // 480GB PNY CS1311 SSD/2TB Seagate HDD // Display: LG 50" 4k TV // Rii Wireless Mini Keyboard w/Touchpad/Xbox One Controllers Donated.
Son's System: i7-8700 // Cryorig H7 Quad Lumi // ASRock Z370 Extreme 4 // 16GB (2x8) GeIL Potenza DDR 3200 // EVGA XC RTX 3060 // Corsair 275R Airflow // EVGA Supernova G5 650W Gold // 525GB Crucial MX300/1TB WD SN550 // Display: ACER Nitro VG240Y PBiip / Dell P2417H // Corsair K60 Pro SE // Logitech G203
Daughter's System: i5-9400 // Cooler Master i71c // MSI H310M Pro VDH-Plus // 8GB (2x4) Leven DDR4 2666 (2400) // Zotac GTX 1060 3GB Mini // DarkFlash Micro ATX White // Corsair CX550 // 480GB PNY CS1311 SSD/2TB Seagate HDD // Display: ASUS VG245H // Redragon TKL Mechanic Keyboard + Mouse
Ryzen 5 1600 // Gigabyte B450 Aorus M Retired.
5 minutes ago, Not Wills said:
I think it is the motherboard limiting the voltage or frquency. Youll have to see what other people say
I saw someone test this motherboard with r5 3600 it had the same results of 570x
but it's supposed to run at 3.7ghz without any problems
I didn't reinstall windows after i upgraded from the i5 3450 to this cpu
Should i ?
well i can tell you the normal 1600 stock boost is 3.35ghz. Seems like maybe you actually got the normal 1600 or your BIOS thinks you have the normal 1600.
 Share
