Search In
  • More options...
Find results that contain...
Find results in...
Thinking about doing water cooling in my next pc build
So my next upgrade is gonna be:
EVGA GeForce RTX 2070 SUPER XC Ultra
Ryzen 7 2700x
Asus rog b450-f
Nzxt c series 750w
Corsair 570x case
16gb ddr4 3000MHz
What custom water cooling should I get
Ryzen 7 2700x
Asus rog b450-f
Nzxt c series 750w
Corsair 570x case
16gb ddr4 3000MHz
Why go with a last gen CPU? Also custom water cooling is called custom because it's not a kit, so it's hard to "get a custom water cooling". You would basically have to purchase components separately (tubing, fittings, pump, res, cpu block, gpu block, coolant, rad(s) ). I know corsair makes (or used to make) some water cooling kits but these were rather entry-level with aluminium radiators.
you shouldn't. you should spend your budget on better components that give you real performance. the only time custom watercooling is reasonabl is when you have the best components you can get (10900k or 3950x and 2080ti) and still have money you want to spend.
Any reason why you need watercooling?
A good air cooler can perform just as good.
Watercooling needs constant monitoring make sure the pump working.
With air cooler it's visible.
Ryzen 2600 @ 4ghz | Radeon RX580 | 32gb HyperX 3200mhz | 500gb Samsung PM981a | 5 TB HDD | Corsair CX450
Safe yourself Money and stress. Custom Watercooling is a hobby of its own and not something you do just for better cooling.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
The money needed for a custom loop is far better spent upgrading components. For example a 2070S to a 2080S, a Ryzen 3000 if ur making content or a 9900k or 10600k for pure gaming. (with matching motherboard ofc). Adding in more SSD space so u can move away from HDD mass storage.
Once you have that , THEN go into custom loops.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w | VDU: Panasonic 42" Plasma |
GPU: Gigabyte 1080ti Gaming OC w/OC & Barrow Block | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + Samsung 850 Evo 256GB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P |
Yeah I  think that's what I'm gonna do thank for the help
