Search In
  • More options...
Find results that contain...
Find results in...
1866 MHz memory in H87 motherboard?
Go to solution Solved by Mateyyy,
Most H87 boards were limited to 1600MHz on the memory iirc, so yes the 1866MHz memory you have will work, it's just that you'll have to be running it at 1600MHz most likely.
Is it possible to use 1866 MHz memory in a H87 chipset motherboard?
And if it works does it "downclock" the memory to 1600 MHz?
Thanks in advance!
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
Ok, thanks!
 Share
