Monitor between 500-1200€
Juriga
I got an LG 27GL850-B monitor this year , it had a dead pixel on the top left which really isnt visible at all so it didn't bother me. This week for some reason another dead pixel popped up out of nowhere. It's right in the middle and very visible especially on darker screens. There is no backlight bleed or IPS glow which is amazing compared to the PG279Q I had that was absolutely horrible in terms of backlight bleed.
I got lucky enough to get this monitor for free as well so I really shouldn't be complaining at all about 2 dead pixels but I'm worried more may pop up and it also kind of sets off my ocd. Otherwise I love this monitor but I'm looking for something better I guess and I could use this one as a second monitor, I've been looking into Ultrawide monitors as well so i'll gladly take opinions and such on that.
No idea if this will work for you, but I fixed half a dozen dead pixels on my Elitebook a year ago by rubbing them with my fingernail.
No idea if this would work for you but it did for me.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
I kind of tried this with a pen covered with a cloth but it didnt do anything :/
The GL850 is a solid monitor, low contrast but otherwise pritty good.
Check out the below thread, it will help.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
It's absolutely great, I really like the monitor itself. I remember you recommending a few others a few months back especially with the new OLED lg monitor coming out but that one is just way too big for me. I've considered getting a second GL850 but i'm scared of it having other issues or such.
I would say these 2 are the main rivals of the GL850, similiar price point and only minor differences between the three.
https://www.rtings.com/monitor/reviews/gigabyte/aorus-fi27q
https://www.rtings.com/monitor/reviews/asus/tuf-vg27aq
I'll add the 850 so that it's easier to compare them.
https://www.rtings.com/monitor/reviews/lg/27gl850-b
And here's a link for a table tool, if you want to look for even more options. You can add even more filters from the "add columns" button.
https://www.rtings.com/monitor/tools/table/29693
I definitely was looking at the VG27AQ before I got the 27GL850, I definitely like the look of it a lot more honestly in terms of design if I have one complaint about the LG I really don't like the stand for it and the overall material doesn't feel as premium as the Asus stuff.
