fan replacement Fan Replacement - MSI GTX 1080 TI Armor OC
Fan is fan - it's only job is to blow air, nothing more. So china fan or original fan do the same, except noise level.
You should plug other fan to motherboard because card controller may be not good for it.
I had card that works in 80% fan speed for the same reason. And it works good even today. I'm just using vsync, so I don't have that high temperatures.
If we're talking about temperatures - 80%, 100% - I don't think it will make a big difference. Whatever you do will be ok, it's only fan. If you add fan close to radiator on your card, you'll be ok. You can even mount bigger one using zipties and plug into motherboard. I have old card "repaired" that way (temps the same, less noise than original fan).
Of course if you have glass case and you must have everything looking fancy, you have problem and the only solution will be buying whole GPU cooling.
